I can see the midi triggers showing up on tab 99 but is there any way to record/map the triggers as macros or any kind of Show Control Event trigger? If not is there any chance of this kind of feature in the future?
is this about a Learn function, or the ability to use Show Control to assign incoming midi event to a console action?
I think it is more about a learn function. I am still new to using Show Control
It may be a gap in knowledge, but basically I can see the MIDI Raw coming in, I just can't find where I can use that or record it, in order to map buttons to triggers or events on the console, I am currently testing offline with Nomad but am wanting to set up a showfile to bring to and use on Element Consoles with fewer buttons or my Ion XE when I want to expand capability.
in the Show Control tab (Tab 11) type
[1] [/] {Type} {Network} {External} [Enter]
this creates a new show control event list
[1] {MIDI String} <configure MIDI string> {OK}
{Action} {Macro} [2] [Enter]
this will create event 1 (within the eventlist you created in the step before), makes it listen to a specific MIDI string and execute macro 2.
the available actions in the show control tab are: Cue, Sub, Macro
Thank you so much Ueli I really appreciate it! I was apparently looking in the wrong place, and didn't think of it as a network thing.
