pixel maps and inhibs
Need your help.
I have an on camera cue that uses a pixel map. We are using the chroma q stdio force d 12, these are 8 channels units, think of them as 2 fixtures glued together, each has 2 daylight channels and 2 tungsten channels.
I'd like to set up 4 inhibitive submasters, one for each channel.
I've patched the units in both the regular channel way and also in the pixel map way. I have made the inhibitive subs, using normal channels but they don't have any effect on what going on in the media server.
I guess in a sense I am trying to inhib the DMX values themselves.
Any Ideas?
thanks,
Jim
  • Try putting the intensity for the pixel map server channel in your inhibitive sub.
  • Unless I am missing some thing..
    I think that would inhibit everything in that server, not just one of the parameters.
  • From the Pixel map manual-
    http://www.etcconnect.com/docs/docs_downloads/manuals/Eos_Family_v1.9.5_Operations_Manual_Supplement_revA.pdf
    Server Channel Controls-
    {Crossfade} - used to adjust the priority when devices in the pixel map are also used as desk
    channels. -100 gives the pixel map priority, and +100 give the desk channel priority. At 0 (the
    default) the output is calculated HTP for intensity and LTP for NPs.
    Not sure If can put this parameter onto a submaster since it is a -100 to +100 scale. Being able to do this would be great for live applications.
    You could also try putting the layer channel {intensity} into your submaster to give you finer control.
    good luck
  • If the pixel map server is what's playing back to these lights, then I don't think you can place individual parts of the pixel map on an inhibitive sub.
    Perhaps there's a way around this... I've only used intensity pixel maps, multi-parameter ones so I'm not sure if this is possible, but perhaps you can make a layer that's a black square over the lights you want to "inhibit". Put hat on an intensity master, effectively adding on a layer of darkness to that area of the server.
