EOS Effect Wish/ maybe Offset
Hey All,
Looking at effects and Ive got a Bunch of LEDs in an Array. Looking to Build Some Effects where instead of Cascading over all fixtures We get each of the columns to chase.  I get Setting the Group to 1 but I guess I need a wings option. ( Similar to Wings on the GMA) There are 5 Leds per tower 10 Towers.
If this something that we can acheive or am getting at a Wish List Option?
Any Help Would Be Great,
Best,
Patrick
EOS 1.9.10.9.0.21
  • How are the fixtures patched...in sequence per column?  if they are by colum build a group for each column and then apply effect to group 1 through 10 group 10 i think...i am not at console
  • As each tower has the same number of LEDs, this is easy.
    Adjust the Grouping of the effect and ensure the selection order is correct.
    I believe you'll want a Grouping of either 5 or 10 as you've got 5 LEDs each and 10 towers.
    Your selection order matters, I forget whether you need to select them up/down each tower or around each level of the ten towers.
    - Make a 'real' Group that's got the right selection order to make it easy to do again.
    Grouping is how the effect gets spread across the selected channels, and it defaults to 'spread out'.
    (I have absolutely no idea what you mean by "wings", I've never heard that term before in relation to Effects.)
  • There have been several occasions where I wished I could apply a relative effect to a grid of lights (LEDs) that would result in in cocentric rings of color moving in or out via Hue and Sat.  I could then adjust them live with encoders. As each group would have a different number of channels, adjusting the Grouping would not accomplish this.  Therefore, it would be helpful to me if I had the option to apply effects to groups en masse instead of the channels within the groups.  I think this could also help Patrick- especially if he had different numbers of units on his towers.
    Is this option being considered?
    B Smith
  • Hi Brent,
    The effect you describe is built into the effect layer of pixel mapping. Have you spent any time with that feature?
  • I was kinda afraid you'd say that.  I haven't.  Is it easy to pick up?
  • ETC provided an excellent step-by-step tutorial/training guide at CUE on using Pixel mapping that guides you through the philosophy, patching, creating maps, and using the feature. I'm not sure how to get it officially, and don't feel comfortable publishing the CUE document without their permission, but hopefully somebody from ETC will pipe up with an answer.
    The document is called "Eos_Family_MediaServerControl_v1.9.8revA.pdf". There may be a newer version.
    It's really not that daunting. The steps are:
    1. define a virtual media server channel, and one or more media layer channels (in your case one effect layer) in the Patch. No addressing required.
    2. defining a pixel map to associate the layout of your pixels with the address of the physical fixtures.
    3. start using your new pixel map(s) with the ML control.
    Like any technology, there are a couple of gotchas and I-wish-I-would-have-known-that-earlier moments to stumble over. The 2 trickiest areas for me were learning how to use the pixel map editor and understanding the interactions between a pixel map and a channel when the fixture is patched to both. The latter involves a setting called "crossfade", and might be further complicated if the fixture has a "real" intensity attribute.
  • The Workbook is currently not available publicly online, but if you email me, I'll be glad to send you the PDF.  And yes, the v1.9.8 is still the current version.
    Ellen.white@etcconnect.com
    Hey Brent,
    The feature you're looking for is OTL. It's called "Sub-Grouping" (or something else). However the workaround, for now, is to use dummy channels.
    So if you have 4 concentric rings, the first ring with channel 1, the 2nd ring with channels 11-12, the 3rd ring with 21-23 and the 4th ring with 31-34, make a group with channels in the following order where Xs are dummy channels:
    1, X, X, X, 11, 12, X, X, 21, 22, 23, X, 31, 32, 33, 34
    Make your (absolute or relative) effect have a grouping of 4 and apply the effect to that group.
    Hope that helps.
    -M
  • Hey all,
    I got what I needed to make it work. Just made groups for each tower then Made 5 copies of the same effect then applied each group to one of the 5 effects. If you do the same effect, in playback it still grabs the channel/ group selection and plays it back over that 1 effect. Versus if you play it back over 5 groups and 5 instances of the same effect just different numbers. Its tedious but thanks to my offset macros it becomes a little easier.
    Marc that Sub-Group sounds like exactly what we need, always nice to hear its OTL. =)
    PS Sk8ers Dad, pixel mapping was our original idea, but with the lack of content we came up with it didn't really work. The gradient ones worked best, but still not what we wanted. Plus with such a small array. Even scaling it didn't really help.
