Ion intensity levels not changing in cues
First show with the new board (our first Ion)...
We're running some conventionals, some D40s and 2 VL1100s for a play.  The problem is that the intensity levels for the VLs and conventionals are not changing as programmed. We can go into Blind Spreadsheet and see that the cues have the recorded levels, which do change, but when we run the cues (using Go key), the Intensities on them doesn't change.
NIPs are changing on VLs and D40s, and I think (but wouldn't swear to it) that the D40s Intensities are changing.
I must be in some weird mode, and a lot of head banging trial and error as well as web research has not helped. Any suggestions for things to check/do ?
Thanks in advance!
