Hi.
I am hireing in some Robe 100 LED Beams for a show. Does anyone know where I can download the fixture profile for the ETC Ion? For some reason ETC console profiles are missing from the Robe website.
Thanks in advanced.
Joe
Hi.
Thanks in advanced.
Joe
Hi Joe,
Please check you email for details on how to install this fixture.
Tom
Hi Joe,
The Robin 100 LED Beam is already in the fixture library on Ion, so you should just be able to patch it. The Eos (Ion/Gio) fixture library comes with software releases although you can create your own fixture where needed. If you do desperately need a fixture that is not available, ETC tech support do have a way of providing extra fixtures.
Cheers
Dan
Thanks for the help. I couldn't find the fixture in the library. I will check I am on the latest software version.
The latest release is 1.9.12, there is a possibility it may not be in there as I'm on a pre-release build. If not Tom's email will get you there.
Cheers
Dan
Thanks for you suggestion. I conected to the server and downloaded the latest verson of the library (EosConsole_FixtureLib_v7.6.0.9.1.30). Or should I have downloaded the particular one you mentioned?
I installed v7.6.0.9.1.30 onto the console and the robe 100 LED beam wasn't in the library.
I could make my own fixture profile but I am new to the ion and don't think I could get it perfect!
I have built a profile for the fixture which seams to be working ok. I will just stick to using that for the moment!
Thanks for all your help!
Joe
Hi Joseph,
you downloaded an older file.
This file you need to download from the FTP Site they sent you is:
EosConsole_FixtureLib_v7.6.0.9.0.66.exe
THANKS!
