Recording from Submasters
Hello all,
Is their a recording mode when when you use subs to bring the channels to their desired levels, when you record the cue, the playback does not take control of those channels but leaves it to the subs?
Situation: They sometimes record by subs so make the look, record the cue and get on with the next look, the problem we are coming across is that when we record to cue, those values are grabbed by the playback and the you then cannot have full control by the submaster until you go to a higher level.
[edited by: jonyrainsforth at 1:31 PM (GMT -6) on Tue, Nov 27 2012]
