Calllibrate strollers by address
I have several channels that are 2--fered in my show, and they have strollers--addressed indivually. I need to calibrate as such as they are not currently matching by frame---any suggestions?
  • Hi Michael,
    If you go into Patch > {Fixtures} and copy your existing Scroller fixture, then go to {Edit} and select the Scroller parameter. Hit the {Parameters} key, then under Color you will see a 'Scroller 2' parameter. Select this.
    You can then label that fixture as something like 'Scroller 2'. If you apply this to part 3 of your channel in patch, you will then gain the ability to have a second individually controllable scroller for that channel. You will need to have individual addresses for each scroller at this stage however.
    Hope that's a help.
    Dan
  • Hi Daniel,
    Just saw your post, and that show has since ended---
    That said, your suggestion is the most logical, simple solution suggested (I will definitely try it in the future)!  Thanks!
    MM
