Data key functionality during effects
Programming effects on an Ion.  Is there any setting or shortcut to toggle the [Data] key to show values as default and the effect number when you press the key?  I am running an effect and would like to watch the levels change instead of seeing that it is simply in an effect and having to stop programming to hold the [Data] key down to watch levels change.  Any thoughts?
---D
