EOS with colorblaze 72
When I plug my colorblazes 72 in a net 3 gateway through the network, the EOS freezes. It will reboot after three times then, you have to unplug and replug the cat 5 cable then, it is fine for the rest of the night. I have tried patching as the fixture, default rgb led and just channels, with the same problem
  • What version of Eos are you running and what version is the firmware in the Gateway?
    Is the Gateway plugged directly into the back of the console, or via a switch? Have you tried a different Cat5 or DMX cable?
    Can you please send a copy of your log files to eos (at) etcconnect (dot) com, and describe the issue in the email so we know what it's about.
    [edited by: Richard at 12:13 PM (GMT -6) on Wed, Apr 3 2013]
