Is it possible to renumber some/all cues in a cuelist?
You can use [Move To] to manually renumber cues. If you are looking for an automatic renumber of an entire cue list, there isn't any feature to do that, although I have heard rumours of macros that might exist.
It is also possible to export the cue list as ASCII text or CSV, renumber with a text editor, and import/merge the revised list.
Yes,
Hit Copy To twice and it will change to Move To. Then just move the cue.
Yes. Just say cue 4 (or whatever your first cue is) thru cue 99 (or whatever your last cue is) move to 1. But this will keep the same fractions that already exist. For example, if you have cue 4.5, then 4.6 then 4.7, the meeting cue list will also have 1.5, 1.6 and 1.7.
So obvious when you stop and think about it - but so useful to know
