Importing Strand Shows
Hi there
I am reprogramming a show on the eos that was originally programmed on a strand 520.  The show loaded across brilliantly and better then I expected it would.  Some of the effects didn't come across perfectly (mainly because they are CMY colour chases programmed as step chases, etc).  These needed to be reprogrammed as relative or absolute FX, (which is fine by me - made them alot neater) but the one major downside was the part cues
 The show has lots of part cues and I found all channel values ended up in the highest cue part.  For example, ch 1 > 5 should be in part1, ch 6>10 in part2, and the rest in part 3.  Instead all channels ended up in part 3.  Does anyone know of a way to fix this?  Going through all 527 cue parts and putting channels back into their correct parts is a bit of a dull and time consuming task
Cheers
Brent
