Follow/Hang problem
I have an Ion with v2.0.9 software.  I have a cue with a Follow set.  If I get to the cue through the normal progression of cues using the GO function, the Follow works as expected.  However, if I execute the cue by using GOTO CUE the cue executes but the Follow is ignored.  The same is true if I use Hang instead of Follow.
Is this a bug or intended operation?
