Some Questions and Feedback
Hi there
I've just finished reprogramming the show I am currently with onto the EOS.  Here are some things I noticed while programming
 1- When executing cues with multiple parts, and each part having there on delay time, it would be handy to see when each part is being triggered.  At present there is only the overall countdown for the cue, so it's hard to tell when a particular part is starting to run.  Maybe a countdown on all fade times, delays, etc for each part.
2- It would be great to be able to put a delay on an effect stop.  Currently when a "stop" command is in a cue, it is triggered at the start of the cue.  Even if I put a delay on the channels, or put the channels into a different part with a delay on the part, the stop command is still triggered at the top of the cue.  Anne - I know you have already mentioned that effect entry/exit times will be inherited from cues they are attached to.  Will they also follow any delays on a cue / cue-part?  It would be really neat if they did
3- Is it possible to alter the size/rate on a single channel in an effect.  For example, I have 8 wobblies doing a circle effect out into the audience and the 2 units on the 3 Bar are clipping the border immediatly DS of them.  Is it possible to change the size of those 2 unit only, or do I have to make a copy of the effect, apply the effect to those 2 units only, and adjust the size on the new effect.
4- On the subject of fading size/rate values in cues.  Where does the time for this fade come from.  For example, in Q5 I set all ML's to effect 901 (circle) with a size and rate of 0.  In Q 6, size and rate increase to 100.  Where does the fade time come from.  Is it inherited from the cue, or from elsewhere?
5- On the effect status page I can only view 7 effects.  There are times in the show where there are more than 7 effects running.  I couldn't find a way to page down to view the other effects.  Is there a way to do this?
6- Snapshots triggered from and execute command in a cue seem to take a while to actually execute (i think).  From what I can gather, the snapshot is executed immediatly, but the faders do not move to where they should be for a few seconds.  I haven't played around with this all that much, but it was something I noticed that I thought I should pass on.
8- This is more of a wishlist item - but would it be possible to recall beam pallets and focus pallets by their text lable.  This would be particularly useful for beam pallets by being able to recall from a text lable instead of trying to remember lots of numbers.
 Cheers - BFJ
  • Thanks for the notes, to answer the ones that are questions:
    #3 Sorry, it's not currently possible without using a second effect.
    #4, it uses the up intensity time of the cue (the first part for a multipart cue).
    #5 is fixed in 1.3, the arrow key will scroll through the effects.
    #6 Currently, if a snapshot includes displays, it could take a few seconds to process all of the displays. The slider movement happens after the displays. If you only need the fader positions, only select faders when you record the snapshot and it will be instantaneous.
  • BrentFJ:
     1- When executing cues with multiple parts, and each part having there on delay time, it would be handy to see when each part is being triggered.  At present there is only the overall countdown for the cue, so it's hard to tell when a particular part is starting to run.  Maybe a countdown on all fade times, delays, etc for each part.  -- AV  We will be adding a duration counter for each part shortly.
    2- It would be great to be able to put a delay on an effect stop.  Currently when a "stop" command is in a cue, it is triggered at the start of the cue.  Even if I put a delay on the channels, or put the channels into a different part with a delay on the part, the stop command is still triggered at the top of the cue.  Anne - I know you have already mentioned that effect entry/exit times will be inherited from cues they are attached to.  Will they also follow any delays on a cue / cue-part?  It would be really neat if they did  AV - you could use multipart cues to stage the effect start.  And yes, when we allow effects to use cue level timing, cue and cue part delays would apply.
    3- Is it possible to alter the size/rate on a single channel in an effect.  For example, I have 8 wobblies doing a circle effect out into the audience and the 2 units on the 3 Bar are clipping the border immediatly DS of them.  Is it possible to change the size of those 2 unit only, or do I have to make a copy of the effect, apply the effect to those 2 units only, and adjust the size on the new effect.  AV - -- Not yet, we've been discussing this.  No ETA yet.
    8- This is more of a wishlist item - but would it be possible to recall beam pallets and focus pallets by their text lable.  This would be particularly useful for beam pallets by being able to recall from a text lable instead of trying to remember lots of numbers.  AV - we've discussed this.  It keeps dropping to the bottom of the list because it is far more time consuming.  It'll get in at some point, though....  Thanks for the input!
