I want to recall a part of a cue with unused channel
Hello
this an exemple to explain my question:
I have a cuelist with a cue 9 (third cue of the show) inside, only few channels work, the other main channels will appear in cue 14.
If I use "recall from cue 9", all state is loaded with all 0% for all unused channel
if I use "channel 1 through 24 recall from cue 9". only used channel bring back to there levels.
How grab 0% for unused channels ? I have try to make a block cue for 9 but it is the same result. I understand that Eos copy only values which were stored but maybe an new option like Recall from {State} will be a good way. (it is a Compulite and Hog option).
Thanks for your answer,
maybe there is a way with "copy to" but I'm in the dark with this problem.
