I've just updated one of our Ion desks to V2. The shell shows that we are running V2.1.0 but once booted into the OS it is still running V1.9.8.
Anyone else come across this or have a solution?
Nick
Nick
Hi Nick,
The OS version in the Shell is referring to something different to the software version on the console.
If you clear the command line and press about it will show you the software version.
If its is still showing 1.9.8 then I would re-download the 2.0.1 software from the website and try installing it again.
Tom
Hi Tom,
Already done that within the OS which is how I know it was still running 1.9. I'll download and try again.
Many Thanks
Nick
Tried again but still no luck - help!
Nick
It may be time to call tech support and have them walk through the install with you.
Problem solved - it was the fancy Source Four-shaped USB drive!
Huh? I update my console all the time with the S4 thumb drive. I've never had an issue. Could you please elaborate?
Hey,
As a last resort I just tried a different USB drive and it installed just fine.
I'd reformatted the S4 drive when I first received it, again when this problem arose and tried two different downloads of the installer in case one was corrupt but no dice. The S4 drive mounts fine on a PC and the desk so I don't know where the issue lies.
Nick
