Editing a Fixture / Attributes Names
Hello
There maybe and hopefully is a simple answer to this.
I am trying edit a fixture for our Media Master Pro and I am wanted to move all the position and scale attributes from Shutter to Focus.
The issue I am having is that in focus there is not the same attribute names as in shutter.
Is there a way to create new attributes under focus?
  • Hi Keith,
    I'm afraid parameters are fixed to parameter categories and there's no way of creating your own parameters or renaming them at the moment.
    Focus is generally used for position parameters, and I would expect scale to fall under Beam/Form in most cases. You may well find parameters with names that suit better under the Focus category which you can use.
    Dan
