Unintended consequences with Chauvet Geyser RGB
Two queries related to the fixture description for the Chauvet Geyser RGB in the most recent library updates.
The Geyser is an effects smoke machine - it has a set of LEDs combined with a vertical smoke machine - our use is in place of pyros for a pantomime where we are using several with a Ion running 2.0.1 and a very recent library update (I think its revision 30 or so).  Fixture info at http://www.chauvetlighting.co.uk/geyser-rgb.html
If AutoMark mode is set on the Ion, then any cue which brings up the LEDs and Fog together has the Fog change pushed back into the previous cue, with hilarious or embarrassing (or both) consequences.  Is it possible to change this behaviour so that the smoke parameter is not marked like this?  Currently running without AutoMark :-)
Also, would it be possible for that fixture description to be changed so that the default value for Color Mixing is zero (ie you get the output colour you expect) rather than 255 (it flashes through a range of colours around the selected colour)?  This seems like a very strange choice for a default value.
  Nigel.
[edited by: nigelm at 3:14 AM (GMT -6) on Thu, Dec 5 2013] Changed Smoke to Fog to match up with the attribute names on the Ion
Parents Reply Children
