swap pan/tilt bug
Hi there
I have discovered a pan/tilt bug when you swap pan/tilt and do a focus change to only one of the parameters the other one goes to zero during playback and jumps into position when the cue is done. When you look in about with the channel the value and abs looks fine but the DMX value goes to 0 (0,0) during playback.
Anders Kjems
