Hi All-
I have a couple Cosmic Color Ribbons from Light- O-Rama that I am trying to figure out how to patch and control with the Eos Ti.
The strip is 50 pixels long with individual control RGB of each pixel for a total of 150 channels. per strip They have a "controller" box which can be addressed.
For example I am using 4 strings in this show I am working on. Clearly all 4 of them combined take up more than 1 universe so they are split 3 and 1. One box is addressed to start in Universe 1 @ 1 and go all the way thru 150. Ribbon 2 would start at 151 and go to 301 so on and so forth
Does anyone have insight into how this should be patched- if I use the Generic RGB type it gives me the option of 8 or 16 bit which correspond to 3 or 6 channel control respectively but that then only controls the first pixels.
Any help would be much appreciated.
Thank you
