In the eos offline editor, when I go to Blind Spreadsheet mode and press F4 (Format), the system locks up. The Clear (backspace) key will not erase the command line and pressing F2 (Live) causes the command line to display "LoadCue" followed by the cue number on the spreadsheet. The F3 (Blind) key does not do anything, nor does F4. I searched the manual for "LoadCue" but found nothing. I found a couple of instances of "load cue" with a space, but not a command. The "Q" key also has no effect. If I exit and restart, it cleans up the problem.
What did I do wrong and how do I undo it without exiting?
