Replace With problem
I'm running software version 2.1.2 and I think there is a random fault with the Replace With softkey.
In Blind (spreadsheet view) I can replace most things but while trying to change a Shutter Strobe value of 15 to 255 it fails every time. It takes the syntax but does nothing. I'm doing this because of some fixture swap outs old unit Open Shutter was 15 new one in 255, I've been able to use Replace for many other things such as zoom as a direct change and also CP changes in cue ranges.
Is it something I'm doing wrong or is this a fault?
Stacy/Stuart
