I was wondering, and this may be a long shot, but is there a way to save effects from another user's board and upload them into mine?
Writing my own effects is something that I have yet to master, and I'd like to get a look at someone else's.
Hi Chris:
The other user can save a show file and give you that file. You can then use the MERGE function via the Browser to bring in only the effects from that show (Navigate to Merge>Show File, then only select effects before hitting {OK}). This will then allow you to use those effects in your show. It will save with the show file and not to the desk itself.
Keep in mind that these effects may reference channels or palettes that do not exist in your show, so they may not work right away on your console. It may be best just to look at their show file as a whole to better understand how they created the effect.
Another option would be to view our tutorial videos on creating effects.
These are located here for Ion: http://www.etcconnect.com/support.tutorialseries.aspx?seriesId=12 and here for Element: http://www.etcconnect.com/support.tutorialseries.aspx?seriesId=2 and here for the rest of the Eos family: http://www.etcconnect.com/support.tutorialseries.aspx?seriesId=6
I hope this helps.
Thank you,
Sasha
Great. I'll look into that. Thanks for the quick response!
