Park Selection
Hey Folks!
I recognized that in live I can finish a channel selection with enter and still have the selection in the commandline when I´m hitting Park afterwards (like hitting Preset/Palette and different to hitting Record where I lose selected channels).
But in Park-Blind this is the other way around. I´d like it to be the same as in live ´cause more than one time I wanted to edit parked channels (which is great to be possible) and did "global" changes instead of only changing the selection I wanted to.
For shure, that´s stupid me but I´d like to know if maybe other Operators would agree that I it would be more handy to Keep it the same way as in live.
So please tell me (and ETC) how you think about this.
Saludos
Paul
  • hi paule
    never had the same problem and i'm not sure if i understand the problem correctly. i think what happens to you that you use the Park button in the park display. but you can do it without. in park display: 3 @ 50 Enter, no need for park. now if you want to change that, you can just start with @ and a different value. like this i think your problem should be solved?
  • My fault description was unprecise. And yes I´m using the park button in park display.
    In the case I had problems with it I wasn´t up to change levels in Park but to unpark channels and so my global change was to unpark everything...
    I know I could do the unparking in live but to keep our screen clean we park all our moving light non-dimms and so on and then sneak them out.
    So I won´t see them any more and query @ park won´t work.
    When I do so we have tech till afternoon and then setting up for the evening and I don´t want unnecessary resets. I keep everything parked we used during tech load the show for the evening go to the park display and say "SelectActive_-_GroupX_ (which are the directs for this Show)_park_enter" which works fine. Only problem is when I hit enter before park. Then I will unpark everything.
    No big deal for shure. Just have to take care but I´d prefer it to be in park display same as in live.
    Hope I could make myself clear more or less These.
  • i agree, i like park display as well. and i like it because you can use @ Enter to unpark. i understand your problem better now, but i still claim that if you would avoid using the Park button in the park display, it would behave like you want.
  • That´s right @ Enter sound´s much better than Park to do that! And now I remember that I already knew that once... Thx a lot!
