If I've specified a list of channel attributes on the command line, is there any way to reselect the same channels / attributes to apply a subsequent command?
e.g. after command line: Chan 65 Thru 70 Frame In 1 Frame In 3 Frame In 2 Frame In 4 @ 40, how can I change those same parameters to 50, say, without re-specifying them again? If I just type '@50' the fixture intensity is changed. I've tried double-clicking Select Last, which reposts the whole of the previous command line - which sometimes helps if there has been no other command since the last channel attribute selection, but even then it's still necessary to back-space the old value off the command line and enter the new value. Is there a better way of doing this?
Another example is applying discrete timing to attributes, e.g: Chan 65 Zoom Diffusion Time 5 Delay 5 - is there a quick way of reposting Chan 65 Zoom Diffusion so that those attribute times can be quickly changed?
