Designer RVI Lock Frame
Hello,
I have been working with the new software update and haven't really come up with the best way to set up a designer RVI.
Here are the constraints:
  • The RVI needs to be the same user as the console to follow live/blind/next/last
  • I want to LOCK three frames Magic Sheet/Playback/Tombstones
Here is the problem:
  • Eos doesn't let you LOCK every single frame on the screen, in order to allow you to pull up groups or patch as needed, however, on the RVI I want to lock every single frame so the screens don't flip around on the designer.
Here is what I have doing:
  • I have been creating a 4th frame sized to a tiny sliver off the right, and leaving this one unlocked to flip around with the programmer. Obviously this is less than ideal, but it's the only way I've found to keep the RVI on the same user, and not have the three frames I want locked in place.
Does anyone else use a different set up for a designer RVI?
