Midi Keyboard Submasters
Greetings All,
I use an ION running 2.2 and am trying to connect to a midi keyboard in the hope of being able to play sub-masters back from it, Is this even something that can be done, if so has anybody done it or can anyone direct me on how to set this up?
Zach
  • Zach,
    If you are willing to run through a computer you can do it in the next version of the software. You may be able to do it in 2.2 but you would need a program to convert midi into UDP commands. In the 2.3 version of the software you can use a program to convert midi into OSC (open sound control) which is fairly easy to set up. I work on mac so I use osculator to convert midi to osc. 2.3 is currently in beta testing. so hang in there a bit longer.
