Monitor Snapshots Recalling CIA Open
Hi ETC Team,
I've recently upgraded to EOS 2.2.1 on an ION 1000. I wanted to record a monitor snapshot of a Direct Select window. After making the snapshot, I would recall that snapshot number to be shown the CIA window. I have older show files from older versions that have snapshots running on 2.2.1 and the CIA remains closed. It is only when I make new snapshots that this happens.
This is something that was an issue in earlier versions (1.9, 2.0), but I was able to get around this by closing the CIA window prior to executing with the [Enter] key.
Example:
Step 1.  Monitors are set to my liking.
Step 2. [Record] [Snapshot #] (at this point CIA is open giving you the option of what type snapshot you desire. By default [Monitors] is selected)  With the mouse, I left click on the CIA "down arrow" closing the CIA and finish the command line with the [Enter] key. When I recall the snapshot, the CIA remains closed. This is no longer the case with V.2.2.1.
Is this something that is old news and will be addressed in a later version?
I would like to point out that this little error creates more of a work load when in the heat of data entry b/c now I have to always close the CIA when recalling a snapshot with the mouse and then move onto the programming. I do enjoy the new fresh look and features of this version, but I hope to see this problem resolved sooner than later.
Thank you for your time and wishing you all the very best.
Sincerely,
John Nichter  aka JohnnyFocus
Technical Director
RCC CAC Theater
Suffern NY
