I have a group containing channels 161>190. I type -180 -190. It only removes channel 180, not 190. If I reverse the order, it only removes 190, not 180. It works if I make two separate commands. It also works if I type 161 thru 190 -180 -190.
Use the syntax [-] [180] [+] [-] [190]
The [+] is effectively 'and' in this scenario.
