The percentage of completion and cue count down are based on the duration time, which is an aggregate of all of the timing in the cue, including channel level discrete timing. We are investigating ways to provide more detailed cue level IFCB duration. Can't give you a time frame yet, but its on the list of things to do!
Thanks (again) for the suggestion.
Anne
Could we also get the timer to count, even when there is nothing happening?
I use the cue timing for things like house 1/2 and house out when not run through the board and put dummy cues into the board so that I don't have to figure out what a 10 second house out cue is and I can always have the same timing. Currently when dummy cues are in the board, even with a time onto the cue, it does not count for you.
Jay
Hey Jay. Thanks. Yep, that's on the list. We are doing some additional rework (tied to M-part cues) that will show up in 1.5.
Thanks!!
a
While we are on the subject;
When you execute a Part Cue, the cue # and part #'s turn red for the duration of the entire cue. My wish is that as each part completes, its color would change.
That's part of the work that will roll into 1.5 (at the lastest).
Anne
