Altman Phoenix RGBA
My control Board is an Element V2.2.  I  purchased two Altman Phoenix RGBA. They are patched using the profile on the fixture library.  Problems- when I turn the Board on the units come to full. I need to take the units to full then out to gain control. How can that not happen? Also the "no color" of the color picker is very lavender, all the other colors when using the picker or even calling a specific gel are also shifted on the spectrum.  How do i tweak to 3200K (ish) so the color picker software is closer to being correct. I can do it by manually manipulating the RGBA levels but it would certainly be easier to use the picker!
