Questions about Next-ing through a RemDim'd channel selection
I have a couple of questions about the behaivour where a RemDim is applied to a channel selection, and you then Next through that selection.
The scenario I'm asking about is this:
a) cue is live on stage
b) apply RemDim to a channel selection (e.g 91 Thru 96 RemDim Enter)
c) Next through that selection (each channel in selection is further RemDim'd - e.g. command line looks like Chan 91 Thru 96 : Chan 91 Rem Dim)
d) when Next-ing through the selection, modify attributes of each channel in turn - e.g. pan/tilt
e) press Clear (all intensities snap back to original cue state)
f) Update cue
This is really useful for seeing and updating individual fixtures within a cue, but I have a couple of questions:
1) When clearing the RemDim (step e), is there anyway of returning to the previous levels in a non-zero time? (to save lamps and eyes)
2) When modifying the attributes (step d), it's only possible to maintain the RemDim'd state by using encoders. If you apply a palette to the selected fixture through direct select or command line, the RemDim is immediately lost and all intensities snap back to the cue state. This is very annoying :)
The steps above are very quick - however to avoid losing the RemDim when applying palettes and the snap-back to previous state, I need to use a different approach that involves a lot more typing - so I don't know if I'm missing something or there's a more efficient way of achieving this that avoids these two problems?
  • i would suggest using Highlight. i think that would solve all your problems...
  • Thanks, Ueli. I had a quick look on Nomad, and it looks like Highlight with a RemDim level enabled in Setup would definitely help. Coming out of Highlight still snaps back the intensities, though, even if there is an Up time configured for Manual Control in Setup.
    Also I'm seeing something weird with an Up time set for Manual Control (may be a bug?):
    - Manual Control Up time set to 4 seconds in Setup
    - Apply RemDim to a channel selection (e.g 65 Thru 70 RemDim Enter)
    - Next through that selection => rather than each channel in the selection coming up in sequence, three or four channels come up each time I click Next, e.g.
    ... 1st Next - just 65 is at cue level (as expected)
    ... 2nd Next - just 66 is at cue level (but snaps)
    ... 3rd Next - 67 through 70 all fade to their cue level together
    ... 4th Next - 67, 69, 70 go out, 68 stays on, 66 fades in
    ... 5th Next - 66, 68 go out, the other 4 channels fade in to their cue level
    ... etc, etc..
    After removing Manual Control Up time in set-up, and the Next behaivour above returns to normal (one light at a time). This is with the 2.3.2 release.
