Problem with GIO built-in, multi-touch displays
Hi all, Just purchased a GIO and am having issues with the built-in, multi touch displays. The display on the right (Display A), does not recognize touch commands, only mouse clicks. The cursor actually shows up and moves around on Display B when you touch Display A. Touching Display B registers the touch but not consistently so. Board is up to date on software (Ver 2.3.2).  I've tried the touch screen test multiple times without success. I cannot get Display A to register as a touchscreen. Is this a hardware issue? Is there anything I can do to reset the displays?
