I'm having an issue with the Ion controlling the original (old old school) Chroma Q scrollers. The lines terminated... They function perfectly off the Express. Any suggestions?
Can you describe what is happening, are they working at all? Are they twitching?
Have you tried patching a show file 1 to 1 and they just using the wheel to control the correct channel to see if they move instead of patching them as a scroller?
Tom
You probably need to disable RDM.
If the scrollers are plugged into the console ports then you need to exit to the shell via the browser.
Go into the setting menu. The click on Local I/O on the right.
You should have a RDM tick box for each port. Untick them both and then click accept at the bottom.
Then click primary to get back into your showfile.
Tom
