My ELO 2201L isn't being recognised by my ION. has anyone else had this issue/ have a solution,
thanks
thanks
Hello, Michael:
The ELO 2201L is a multi-touch touchscreen that is not compatible with early versions of the Ion. If your Ion has only 1 network port at the back then it only supports specific single point touchscreens.
You may find this article helpful:
Is your Ion an older model?
Thank you,
