Can anybody tell me about snapping to black using an ION with the latest version of software?
Problems are as follows: I am getting mixed results with snap to black commands. I am controlling 112 ColorSource Spots and 4 ROBE Robin DL4S's with an ETC ION V2.3.3. Sometimes I WILL get an immediate intensity out and sometimes I will get a 1 or 2 second FADE to black despite a cue time of 0 and no discrete timings but it is not consistent through the whole rig.
This problem is present with Cue times of 0 and when manually sending a ch @ OUT command.
My system is sending data to the ColorSource spots over sACN to ETC Nodes / single channel gateways and out from there to DMX. The ROBE's are stricly sACN, no gateways inbetween.
I don't believe it to be a data speed problem as a straight to black command would result in a lag rather than a fade out.
Any insight would be appreciated.
Edit: Just an update on this, I only experience a slow fade out when snapping to black when the instruments are at low levels. This does not seem to be a problem when they are a full then go to black
Garreth Lau
Artsclub Theatre Comany, Vancouver BC, Canada
