It seems that I cannot control the speed of the rotating gobos with the current profile.
Am I doing something wrong?
Hi Charles:
Looking at the manual for the Roboscan 812 it appears that the only speed adjustment available is the Color/Gobo Speed in 7 ch mode. The encoder for this parameter in the in Color section.
The manual is rather vague as to whether is should actually change the rotation speed or the gobo itself and it is also noted that it is only available when tracking mode has been enabled at the fixture itself.
Thank you,
