Do you know which software version you are running? You can find by pressing [About] with a clear command line.
If you edited a cue in Blind then this would be a change and would cause an * to appear after the show file name.
Thank you,
Sorry for the delayed response. I managed to perform a deep clear, and the show still has the same issue.
I'm open to new recommendations, Sasha. This is frustrating.
Is there any way to determine WHAT the changes are between two versions of a show file (or before a Shift-Update, what the console thinks has changed since loading the show)? If so, it might be possible to deduce what is causing it from that.
Alternatively, I would be willing to send you the show file to see if your team could resolve it.
