Hi. Our access point is dying and before purchasing a replacement I thought i'd ask to see if anyone had any ideas regarding particular brands models or specifications that I should look out for when in use with an ION desk? Many Thanks
There's not a big difference in price between routers and access points these days, and there are more options available in the router market. I'd probably buy a router today and disable it's routing features.
I have an Apple Airport Express and an Airport Extreme that I use on different projects. They're both solid and relatively easy to configure.
This router gets great reviews for range, and for $60, it's hard to go wrong. If I was buying a router, I'd probably buy this one:
I can't really justify the newer, more expensive AC routers for an Eos access point. a 5Ghz network is plenty fast. Depending on the radio frequency interference, you may actually get better range with a 2.4Ghz network. All worth trying.
