Eos/Ion 1.4.1 now available for download
Please see the download sections of the Eos/Ion product pages for sv 1.4.1.   This software addresses a number of critical defects discovered in the 1.4.0 release.  You'll also find a download of 1.4.1 release notes; this identifies exactly what issues have been addressed.
Thanks much.  Happy programming.
Anne
[edited by: Anne Valentino at 5:55 PM (GMT -6) on Thu, Jun 19 2008] [edited by: Anne Valentino at 5:54 PM (GMT -6) on Thu, Jun 19 2008]
  •  http://www.etcconnect.com/docs/docs_downloads/console/Eos-Ion-Console_Software-v141.zip
    =   HTTP Error 404 - File or directory not found.
    not yet...
    [edited by: tryggve at 6:40 PM (GMT -6) on Thu, Jun 19 2008]
  • Hi Tryggve
    We are aware of the broken link. It will be fixed end of your afternoon, Friday.
    Sorry for the inconvenience.
    Hilsen
  • The underscore between Console_Software in the URL should have been a hyphen (Console-Software). I've fixed that problem, and I apologize for the delay in getting your software!
    Best,
    John Kuehl
    Web Marketing Specialist
    ETC
  • Exactly what are the "critical defects"? We just opened a show last week running 1.4 and I do not like to mess with the board during a run.  Is it critical enough to risk it?  The release notes only specifies 'bug fixes'.
  • Oh, found the list of notes.  Firefox didn't render the PDF all the way.  Should I upgrade?
  • If your show is already running and you aren't experiencing any problems, then I wouldn't if I were you.
  • Jason's suggestion is a good one.  If your show is in the can, and all is well, you should probably wait until you start a new production to upgrade.   These were the issues addressed in 1.4.1
    Levels that are inhibited snap when fading to next cue.
    4210 After pressing the "mode" button on the encoder screen, the Encoders no longer work.
    4198 Crash if in Flexi time mode and enter setup
    4193 Marks not displaying properly
    4186 Follow time countdown not displayed if multiple cues are running
    4184 Fixture "Iris" Parameter Defaults are incorrect
    Workaround: Manually set the home value to 0.
    4181 Martin - Mac 2000 Performance Animation Wheel Problems
    4174 Random step based effects not working
    4169 Deleting all Cues in a cue list is not Undo-able
    4167 SHELL - user can modify settings for the integrated console monitors
    4166 SHELL - dialog windows should not be moveable
    4162 Channel Summary display is very sluggish when flexi-channel & expand are on.
    Workaround: Don't use flexi channel and expand at the same time
    4153 The CIA is getting stuck in Patch mode or Update if the about window is open
    4151 Selective storing gobo parameter to a beam palette does not record positive values
    4149 Re-recording a live Cue causes the Link not to work.
    4148 In the About display, Patch tab, selecting an Address is re-patching your fixture.
    Workaround: Do not use About Address in patch mode
    4119 Client consoles don't track sub movements
    2960 RED, GREEN, BLUE Parameters should be on SAME ENCODER PAGE for all LED FIXTURES
     a
    [edited by: Anne Valentino at 8:41 PM (GMT -6) on Mon, Jun 23 2008]
