With all the new flexibility on faders is there a way to make one of the buttons act like a proportional fader bump button to momentarily flash the intensity instead of presetting the NPs?
Hey Gregg. And would you expect such a control to ignore the NP content entirely? And if the button is set with timing? Do you expect there to be some manner to bring the NPs in?
anne
It seems there is no way to bump an intensity master sub. I would expect "bump" to bring the intensity to the recorded sub level, and the NPs to the recorded sub level, in bump time. If I wanted the bump button to behave as mark, I would use "Mark NPs" instead of bump. Is there a solution that allows me to press an i-master sub and have the intens and NPs move to the recorded level?
This is currently expected behavior. Your best approach would be a feature request in the Feature Request section of this forum.
So to confirm, in Eos there is simply no way to bump an I-Master sub?
That's correct.
