2.5 Bug on ION - Live Table Display Inconcistencies
I just updated our Windows 7 based Ion 1000 to Eos version 2.5.  Following the update, I created and patched a new show file.  Less than 200 Channels.  Intelligent gear in the file includes 14 x 7" Forerunners, 8 x Apollo Smart Move DMX gobo rotators, a GAM Film FX patched as a two part channel with a dimmer (for the light) and a Fan for the film FX and one Martin Atomic 3000 Strobe set in 4 channel mode.
I'm observing some inconcistencies On the Live Table Display when Flexi is set to Patched Channels and the tombstone Format is expanded to see all attributes.  The first issue is that the Mouse scroll wheel does not scroll up and down in the channel display consistently.  Sometimes it scrolls and sometimes it doesn't.  At all times , the Live Table display is selected, so it is not an issue of not highlighting the correct tab.
The second issue is with Martin Atomic which is patched to channel 150.  Sometimes, Channel 150's tombstone is expanded to show all of the Strobe's attributes.  Sometime it's not expanded.  When it is not expanded, sometimes, channel 145 which is not patched shows up with an expanded tombstone that thinks it is a Martin Atomic.  Additionally, sometime channel 125 which is patched as a simple dimmer displays the expanded tombstone of the Strobe.  I can page up and down and these things change at random.
I have power cycled the console.  I've unpatched and repatched the strobe.  The same bug continues to occur at random.  None of the other intelligent gear's tombstones are behaving out of the ordinary.  Is this a bug that anyone else has seen with 2.5?
