Net3 2 port occasionally goes offline
I have 9 Net3 2 port DMX nodes and have 2 different nodes go offline for no apparent reason.  This is a very rare (several months between failures) occurrence.  Disconnecting and reconnecting from network brings node back online.  Any idea on possible cause?  This has only happened during change over but I fear it may happen during a show sometime.  This was a new install in March 2013.  Board is Ion Win7  A few lines from OnyxConsole log file below
2017 01 26 17:18:39:778 Key_Event U:1: Clear_CmdLine
2017 01 26 17:18:49:579 Network CID 85215DA4-7647-3378-B3BC-3F7F71001663 at handle 0x9 went inactive
2017 01 26 17:18:49:579 QuartzFram Discovery: Component [10.101.100.116:1048,0] has gone offline (CID: 85215DA4-7647-3378-B3BC-3F7F71001663 DCID: ETC DMX/RDM 2-Port)
2017 01 26 17:18:49:579 Patch Disconnected from [10.101.100.116:1048,0] (DCID: ETC DMX/RDM 2-Port CID: 85215DA4-7647-3378-B3BC-3F7F71001663)
2017 01 26 17:18:49:592 Key_Event U:0: ACN_Device_Disconnect 92017012617:23:45:631OnyxConsolRFR 0 connecting from 10.101.1.151
2017 01 26 17:23:45:632 OnyxConsol RFR 0 connection succeeded
and the lines where I disconnected and reconnected node
2017 01 26 17:24:15:278 Key_Event U:2400: Clear_CmdLine
2017 01 26 17:27:16:955 Network Add: CID 85215DA4-7647-3378-B3BC-3F7F71001663 discovered at handle 0x9
2017 01 26 17:27:16:955 QuartzFram Discovery: Component [10.101.100.116:1048,0] is online again (CID: 85215DA4-7647-3378-B3BC-3F7F71001663 DCID: ETC DMX/RDM 2-Port)
2017 012617:28:01:398 Key_Event U:1: 5
  • I have encountered a similar issue with an ETC Net3 4port Gateway sporadically going offline on my current rig. We have removed it and run direct DMX. I have other Net3 4port Gateways on the rig without issue and DMXKing 4 port gateways. My log files showed the following:
    Network 2017 03 13 (The timing for all this in the log files was the same 13:50:19:949) CID58F0D4F5-4E51-3813-91C0-5A69AE127F3A at handle 0x0 went inactive
    QuartzFramework Discovery: Component [192.168.1.107:1048,0] has gone (CID:5BF0D4F5-4E51-3813-91C0-5A69AE127F3A DCID: ETC DMX
    Patch Disconnected from [192.168.1.107: 1048,0] (DCID: ETC DMX/RDM 4-Port CID: 5BF0D4F5-4E51-3813-91C0-5A69AE127F3A)
    This occurred several times during the course of our day while working. My network is isolated, no address service or DHCP, IPs are static without conflict, and only I have access to the network. We bypassed the ETC Net3 4port gateway causing issues and ran DMX from the DMXKing gateways. No additional problems or issues. I am using the same ethernet cable that was going to the gateway and it is working fine. RDM on the gateway, in the shell, on the console in setup, and in GCE is off. This post seemed the closest to my situation I could find. Any insight would be appreciated. We are running 7 universes with heavy pixel mapping and effects today. I've run a similar setup at our primary location for the past 3-4 months without a single hiccup. Initially I just unpowered the gateway, waited a minute, repowered it, and all seemed well, after a few hours the problem started happening again with more regularity.
  • Hi all,
    We'd love to see these logs here at the factory to try and figure out what's going on. Can you send them to hh<at>etcconnect <dot>com and include a link to this forum post in your email so we can match it all up?
    EDIT: Is this issue still occurring for either of you?
