Hi all, i am Using an ETCnomad on my macbook (with the USB key installed), I am running the Client over WIFI to an ETC Ion in primary | Master. my mac is unable to find any masters and i am unsure why this is happening.
i have looked at most of the settings on both consoles, the Ion is currently connected to a router running a static IP so that another computer on the same network can use WYSIWYG. this is already working fine and i am sure that this setup should be allowed to use wifi to connect the network together.
the network is a closed network (meaning that the WIFI and router is not connected to the internet)
so my question is, should i be able to connect my mac over WIFI as a client. and if so, what settings am i suppost to have enabled o both consoles to allow this to work
thanks for any input
