Bug with setting ranges for custom fixture profiles
Hi there!,
I'd like to report a bug that I've found, using version 2.5.2.9.0.8, Fixture Library 2.5.1.9.0.6
I'm making some new fixture profiles, and when I add ranges to a parameter it automatically fills in User Min and User Max. That's very nice and intelligent but offcourse, they're not correct. but I don't seem able to change them. For the Color Select I've got 10 ranges. I want Color 1 to have User Min 1 User Max 1, then for Color 2: User Min 2, User Max 2. you get the point. But Nomad fills in 1.5 - 2.5,  2.5 - 3.5.
I've tried Insert instead of New, but it doesn't seem to help. I've also tried starting with a higher number, above the ones that have been used.
Also the autofill sometimes messes up the DMX-values. And sometimes I can start typing right away, and sometimes I have to delete.
