Rate and Size on submasters, screens
Hi All,
This may have been asked already but without going through the whole forum I wondered if someone could help
I've seen in the 2.5 version and later there is a properties page for submasters
I want to busk on a show and I see you can set an effect on the first fader in properties and then you can set 2 more up so I set these to rate and size, but I do not see these when I put the sub master onto a fader. I just want to have my FX on for example submaster 1 and submaster 2 as size and submaster 3 as rate. Is this possible?
also there used to be a screen page that had channels and cue stack (but showed about 4 cues), now the page has only the cue you are on. I do not want to split the screen in 2 as I have a lot of fixtures and want to see all of them.
is there a way that I can create it like before 2.5
Thanks in advance
