Feature request: Sub numbering extension
It would be very useful if the available numbers for subs were the same as for cues (0.01-9999.99).
Being on the TV/film side of things, I rarely use cues for playback.  For each camera setup, I record a cue that holds the overall look, and use subs for live transitions that occur during the shot.  During a typical television season, very roughly I might record 500 or so cues over the span of four or five months.  For record-keeping and reshooting, it would be great if I could assign sub numbers that matched up with the cue numbers they belong to.  So for example if we're working on a shot that I'm recording into cue 243, and I need to use three subs for a character flipping light switches, I could call them sub 243.1 through sub 243.3.  This would make referring back to previous work a lot more organized and intuitive when recreating or reshooting something we shot hours, weeks, or months ago.  Extending the range for sub numbers above 1000 would also let me put utility subs for worklights etc. into numbers outside the range of the cues.
Matthew Rohn
Local 52, IATSE
  • I am in the same boat. But feel if they would just alllow cue list 1/1-3 load to clear faders we could manually play back our looks on individual sliders then we wouldnt have to make notes of what subs we used. I use the go button once in the last 7 years... i put this in a few times as a request. But film is too small of a market for ETC i believe.
  • I've been thinking about this and have been somewhat confused. If you have hundreds of Subs, are you remapping Subs to Faders for every shoot? If so, why not store your scenes in Presets?
    So you want to assign Submasters 243.1 - 243.3 to Faders 1-3. Instead, Record scenes to Preset 243.1 - 243.3. Then, instead of remapping Faders, keep Subs 1-3 assigned to Faders 1-3, but then record Presets 243.1-243.3 to Submaster 1-3.
    Next shoot, Record to Presets 244.1-244.7 and then assign Presets 244.1-244.7 to Subs 1-7.
    You have a tool (Presets) that you didn't have before, why not use them? Also remember... [Group] [Preset] (243.1) [Preset] (243.1) [Enter] recalls all channels with data recorded in the preset and assigns the value of the Preset.
  • Hi Wuz314159,
    I think you may be mixing me with Ranger's comment above, but here are my thoughts.
    I don't typically have a huge number of subs, much less hundreds that need to be on faders at the same time.  I want the sub numbers to correlate to a cue number or a channel number, whatever that cue or channel number is.  In a typical instance, I might make a sub for a limited and specific transition within one shot, such as an actor flipping a light switch that makes five practical lamps turn on or off as well as a key light, soft box, etc.  If that was created to happen within cue 345.2, It's much more convenient and intuitive for later reference to call it "sub 345.2".  When the shot is done and we move on to a new setup, I might recycle the sub if we're covering the same action in the same scene from a new angle, but most of the time that sub will never be used again... until it is, days or weeks later when we might unpredictably need to reshoot or otherwise refer back to that look.
    The idea to use a preset on a fader is an interesting one, but presets can't do the same things subs do, and when I create subs for this purpose I need all their subbiness--priorities, timings, restore state, HTP/LTP, exclusions, etc.
    I think Ranger was talking about batch-loading consecutive cues onto consecutive faders, which isn't a workflow I've ever tried
  • You could have the cue fire a macro to clear all your subs and to load the presets that belong to that specific cue onto your sub faders.
  • Hi Theatermachine,
    The issue isn't how to load or unload subs, it's about having a unified numbering system to permit efficient archiving of cues and associated subs.  This is probably something that is particular to the motion picture/TV workflow.
    The biggest difference is that we don't typically use the cue stack to create a sequence that then gets played back a bunch of times.  Cues are recorded primarily for archiving and reference purposes.  99% of the time the look in a cue is for one-time use only right when the cue is created.  But it's also typical to have to look back and refer to a certain cue for levels when reshooting or using it to build a variation for a different shot, but at the same time completely unpredictable which specific cue that might be.  So any one-time subs that might have been created for use with that one-time cue would be a whole lot easier to manage if they had an intuitive and shared numbering system.
  • I understand. So in addition to your request, maybe you would also need that amount of fader pages?
  • No, I'm only likely to have a modest number of subs that were created for that purpose by the end of a season or movie, and I won't need any of them loaded to faders except when we're in the associated cue(s) shooting that particular setup.  It depends on the project and the DP's style, but in my experience on most gigs you only need to do a lighting gag once in a while.  The cue numbers in which I might need to do that are essentially random, so forcing the gag sub to be an integer 1000 or lower is very limiting.
  • From what i recall presets can only record effects live. In film it all live and you usualy on get 1 chance to play these effects and looks before its go time. No time for building macros and you have a bunch of preloaded blank subs add numbers and go. We get told by the head lighting tech a bunch of numbers and various levels they say good luck rolling. My work flow has been simular, a cue holds the base look and 3 to 6 subs with lights going on or off floruo flicker and then grab the cuelist master and shake it up and down when the machine explodes the fireball goes off and the stunt double jumps out window. So timing is everything and its all on subs so they can have any look at any time. I would love to get in touch with anyone willing to make a board for film.. Or if ETC would make boot option in settings with all the options the film folks would use. As we are two completely different workflow structures.
  • Maybe it’s because I’ve been a programmer by trade for too long, but doing both Live and Film/TV programming I don’t have this issue.
    I typically put looks into cue lists and then load those individual cue lists onto faders. Then I have a set of faders that can do effects and presets. That combined with direct selects and macros, I work with two touch screens and a 2x10 fader wing in the eos world. The numbering stays with the cue list associated with that shot.
    I wouldn’t say the workflow is all that different or the hardware, but it’s the execution that changes so I’m not sure that a software solution is needed for a preference?
