Hi Adam
As a temporary suggestion until the fixture library is confirmed by someone-
Have you experimented with the user definable HOME Preset. In SETUP {Show} you can set the HOME preset. (999 for example) In this preset you can store whatever data you want for any of your fixtures. It will then reference this Preset when you press [Home].
A few points to note however- For any attribute (or whole fixutre) that you don't include in your HOME preset, the desk will then reference the library home information. (This is set within the library data and cannot be changed). You can change a fixtures HOME values when you create your own personality.
As for MIN/MAX until someone verifies the library info for an Alpha 300 i would just avoid using MIN/MAX.
Hope this is of some help.
Tom
Adam, home for shutter parameters should be open. Will look into this. All manufacturers default these things differently. We try to catch the home values and change the defaults so they are consistent. Sometimes.... they slip by us. So, you can adjust using user defined home, but please do continue to let us know when you find values that are not as desired.
Thanks much!
anne
