How do I patch multiple dmx addresses to one channel
and how to do patch multiple stage pin addresses to one channel all on a etc ion
Alex,
Open the Patch tab (Tab 12).
Make sure that you are in Channel order, so that the left column title is "Chan". If not, press the [Format] key.
Type your channel number, then "at", then the list of your addresses or dimmers. For example:
1 at 2+8+17+19
This will patch addresses 2 and 8 and 17 and 19 to Channel 1. You will see that Channel 2 has 4 parts, each with an address.
If you need to patch an address in a specific universe (above 512), then you would use Universe/Address, like
2 at 2/57+59+61
This will patch addresses 57 and 59 and 61 from the second universe to channel 2.
It's the same process for "stage pin" addresses - they are just addresses that correspond to the dimmers in your venue.
There are good Ion training videos that cover this - you can watch them them at http://www.etcconnect.com/EosFamilyVideos/Level-1/
Hello, can I do the opposite? If I want to patch adresses 2, 8, 17 and 19 to four channels starting at channel 1 (then 2, 3, 4 ) without typing one by one, can I do that? Like I could on Cobalt? Thank you for your reply
No, this is currently not possible in one command line.
