Eos adding an effect to channels when no effect is programmed into the cue
I'm running an Eos with 2.6.1 software. I've been running a show for three weeks now and a couple days ago the console started sporadically adding an effect to my quantums in two cues where there are no effects recorded into the cue at all. It happens at the same point in the show every time, but it doesn't happen every time I run the show. I read the bug fix notes for 2.6.2 but this doesn't seem to be a known issue. Any ideas? Thanks.
Andy W.
