Copy Subs to New Show
 Running Ion Element. Is there a way to copy all of my subs into a new show file?
Thank you all in advance!
  • you do it the other way round. instead of copying from your current showfile to a target showfile, you merge from a source showfile to your current showfile.
    so with your target showfile loaded you go to the CIA, File > Merge, choose the source showfile, press Enter and from the following dialogue you choose Sub. if you want to be more precise and only pull a certain range of subs you can use the Advanced button.
    Merge actions are not undo-able so you should Shift-Update before merging.
